Hilfe!! 8700K WHEA-LOGGER
sew333
Hi. My question is i dont know why i get WHEA-LOGGER in day 21.01.2018. My system was currently idling when i remember. Windows 10 Fall Creator Update build was 16299.15
A spam of: WHEA Event ID 19 CPU-corrected hw error
And only one : WHEA Event ID 47 memory-corrected hw error
Here are screen with one of them:
My pc:
8700K stock, MTE on, 4700mhz auto clock
Asus Z370 Pro Gaming
16GB DDR 3000MHZ ( XMP ON)
Gtx 1080 Ti Aorus
Corsair 750 Rmi
SSD Crucial 525GB
HDD TOSHIBA 500GB
Windows 10 clean install 1709 Creator Fall Update
All settings in UEFI are stock,defaulted . BIOS : 0215
Only XMP profile is on.
Any clues why on 16299.15 i get hardware corrected errors when on newest builds not?
All settings in UEFI are stock,defaulted . Only XMP profile is on.
Temps of cpu fine,temps of gpu fine. Never had any single BSOD. Memtest86 no errors. All benchmarks passing, no crashing in games
Only saw that warnings in event viewer from 21.01 using Win 10 build 16299.15 which make think that is something with voltages or software? 16299.192 and 16299.214 builds no WHEA-LOGGERS.
Maybe somebody tested 8700K on 16299.15 build?
English only please !
Hello sew333!
Did you install the latest drivers?
ASUS recently released a new bios for your motherboard. Please check first for the actuality of your drivers. If the error persists, then install the BIOS update.
I installed from pendrive USB Windows 10 Fall Creators Update 16299.15
My system was currently idling when i remember. Errors starts showing on IDLE in event logs in 3 a.m and finished at 4:00 at noon.
I updated then to 16299.192 and 16299.214 builds no WHEA-LOGGERS.
Any ideas why on 16299.15 was getting WHEA?
I dont update bios.
Maybe something installing in background causing this like functions or update? Because it started at 3:00 am . Its time on windows task shedule.
No. I have WHEA-LOGGER on 16299.15 ( its october 2017 before meltdown / spectre ).
Yes it was 16299.15 iso from microsoft.com
Pobierz Windows 10
MEDIATOOL ( 16299.15 )
Installed 16299.214 ( january 2018 meltdown / spectre fix ) and no WHEA-LOGGER
you have already asked all hardware forums why do you think we should reply?
suspect a defect and you should send the part back....
I think it's nice that you're here, but you posted the same post in so many other forums! so my question is, what are you doing here? continue to be happy.
