Dann würde ich mich aber für die Version mit der Zapfanlage entscheiden. Die kühlt ja auch noch zusätzlich
Game Ready for DirectX 12 Ultimate
The new Game Ready Driver provides full support for the new DirectX 12 Ultimate graphics API. This includes support for DirectX Raytracing (DXR) version 1.1 as well as support for mesh
shaders, sampler feedback, and variable-rate shading (VRS).
Additionally, this driver supports Hardware-accelerated GPU Scheduling when used with the Windows 10 May 2020 Update.
New Features and Other Changes
Supports DirectX 12 Ultimate
Supports Vulkan 1.2
Supports hardware-accelerated GPU Scheduling.
Supports CUDA 11.0.
Application Profiles
Added or updated the following SLI profiles:
DCL - The Game (NVIDIA Turing GPUs and later)
Jiu Xiao
Monster Energy Supercross 2 - The Official Videogame (NVIDIA Turing GPUs and later)
MORDHAU (NVIDIA Turing GPUs and later
Overpass (NVIDIA Turing GPUs and later)
Planetside 2 (DirectX 11)
Sniper Elite V2 Remastered
Spyro Reignited Trilogy (NVIDIA Turing GPUs and later)
Surviving The Aftermath
System Shock (NVIDIA Turing GPUs and later)
The Fisherman - Fishing Planet (NVIDIA Turing GPUs and later
Warhammer Underworlds: Online
Wolcen: Lords of Mayhem
Fixed Issues in this Release
[Just Cause 2]: The game does not detect CUDA files which results in missing "GPU Water Simulation" and "Bokeh Filter" settings. [2994570]
[Sea of Thieves]: Issues with game rendering occur. [200614095]
[Resident Evil 2 Remake]: The game may display random object and menu flickering. [2997880]
[Devil May Cry 5]: The game may display random object flickering. [2997814]
[Divinity Original Sin 2 - Definitive Edition]: The game experiences low performance when hardware accelerated GPU scheduling is enabled. [3009631]
[Notebook]: Windows Mixed Reality headsets may display jitter when connected to the HDMI port linked to the NVIDIA Optimus notebook integrated graphics. [2971312]
[G-SYNC]: G-SYNC does not work with DirectX 9 games if "Disable full screen optimizations" is selected. [2969897]
Display brightness increases while enabling GPU scaling. [200612966]
NVIDIA HD Audio may disappear after display goes to sleep. [2807732]
The cursor turns into a grey rectangle when playing YouTube 4K HDR videos. [3009602]
Windows 7 Issues
[Notebook][H-Clone]: With the integrated graphics processor as the clone source, display settings cannot be changed from the NVIDIA Control Panel. [200594188]
Windows 10 Issues
[Sunset Overdrive]: The game may display random green corruption if Depth of Field is enabled from in-game settings. [2750770]
[VR]: HDCP errors occur with Valve Index VR. [2967616]
[Call of Duty: Modern Warfare]: Color banding can occur in the game after enabling Image Sharpening from the NVIDIA Control Panel. [2889337/3028436]
[Call of Duty - Warzone]: Freestyle does not work. (200593020)
[Forza Motorsport 7]: The curb may display a black strip during a race on certain tracks. [2781776]
[Zombie Army: Dead War 4][Ansel/Freestyle]: The Ansel & Freestyle tabs are unselectable.[2810884]
[Tom Clancy's Rainbow Six Siege][Vulkan][G-SYNC]: When playing the game in Vulkan mode with G-SYNC enabled, flickering occurs after switching the game between full-screen and windowed mode.[200578641]
To work around, either disable G-SYNC or play using an API other than Vulkan.
[SLI][G-SYNC]: With multi-GPU and G-SYNC enabled, TDRs occur soon after launching an application. [200628981]
[Notebook][The Witcher 3 WILD HUNT]: The game remains minimized when DDS switch is set to Optimus and Automatic, and cannot be restored to full screen. [200628973]
[Notebook]: Some Pascal-based notebooks w/ high refresh rate displays may randomly drop to 60Hz during gameplay. [3009452]
[Notebook][G-SYNC]: Graphical corruption occurs when windowed G-SYNC+V-Sync is On while running applications in Clone/Duplicate mode. [200628911]
[Notebook]: LVDS-display goes blank upon rebooting the system after driver installation on some systems. [200627952]
Planetside 2 sli support? Ich dachte das spiel ist schon seit jahren abgeschaltet... spielen dort jetzt alle hacker unter sich und gehen sich auf den sack oder wie?neuer nVidia GeForce Drivers Version 451.48 WHQL
was war denn vorhin drin?Anhang anzeigen 101840
Mein Liebling hat jetzt einen i5 10600K zu schmecken bekommen. Ich als Koch sage nur: Rennt lecker!!!
Der 10600K holt alles aus der Graka raus. Dank ASRock Z490 Taichi kein Flaschenhals zu spüren.
Ich bin da noch nicht so voreilig, erst einmal schauen was die neuen so an Strom fressenIch denke der Thread wird jetzt so gut wie Tod sein, da die neuen Karten bald da sind. Also schnell alle die alte Generation noch verkaufen, solange Sie noch etwas Wert ist.
Der Abverkauf beginntIch bin da noch nicht so voreilig, erst einmal schauen was die neuen so an Strom fressen
aber bei MF kostet jetzt schon die 2070S gaming X trio 499€, vor nem monat war sie noch über 600
Die noch produzierten werden abverkauft und dann kommen nach und nach die neuen Modelle. Bis es keine GPUs mehr gibt. Der normale EOL Kreislauf.Gilt das auch für notebooks?![]()
Zu einem Schnäppchen würde ich aber trotzdem nicht nein sagen. Auch wenn es die alte Generation istIch denke der Thread wird jetzt so gut wie Tod sein, da die neuen Karten bald da sind. Also schnell alle die alte Generation noch verkaufen, solange Sie noch etwas Wert ist.
Ich denke schon, aber bestimmt erst Ende des Jahres. Einen Vollausbau wird es wahrscheinlich nicht ausgeben bei dem Stromhunger. So wie ich dich kenne möchtest du auch keine GPU die über 300 Watt brauchtGilt das auch für notebooks?![]()
