Folge dem Video um zu sehen, wie unsere Website als Web-App auf dem Startbildschirm installiert werden kann.
Anmerkung: Diese Funktion ist in einigen Browsern möglicherweise nicht verfügbar.
Support For
Red Dead: Redemption II
Added Vulkan Support
VK_KHR_timeline_semaphore
This extension introduces a new semaphore type that uses an integer payload to identify a point in a timeline. The extension supports querying the semaphore, host wait/signal operations, and device wait/signal operations.
VK_KHR_shader_clock
This extension allows a shader to query a real-time or monotonically incrementing counter at the subgroup level or across the device level.
VK_KHR_shader_subgroup_extended_types
This extension enables the nonuniform group operations in SPIR-V to support 8-bit integer, 16-bit integer, 64-bit integer, 16-bit floating-point, and vectors of these types.
VK_KHR_pipeline_executable_properties
This extension allows debugging and performance tools and applications in general to query properties and statistics about the pipeline compilation process.
VK_KHR_spirv_1_4
This extension allows the use of SPIR-V 1.4 shader modules, which in turn allows easier translation from high level languages into spirv.
VK_EXT_subgroup_size_control
This extension enables an implementation to control the subgroup size by allowing a varying subgroup size and also specifying a required subgroup size. The optional feature to allow full compute subgroups is enabled.
Clustered Subgroup Operations
This feature bit allows invocations to perform cluster operations such as add, mul, min, max, and, or, xor among partitions of a subgroup. The operations are only performed within the subgroup invocations within a partition.
Fixed Issues
Some users may be unable to connect their Twitch account through the Connect page in Radeon Settings for live streaming.
The Outer Worlds may sometimes experience an application crash when opening the characters inventory screen.
The Outer Worlds may experience character models being rendered incorrectly on the inventory screen.
Frame Rate may cap or remain limited to 60 fps in some Vulkan API games.
OBS streaming may experience heavy frame drops when using AMF encoding..
Known Issues
Radeon RX 5700 series graphics products may experience stutter in some games at 1080p and low game settings.
Performance Metrics Overlay may cause stutter or screen flashing on some applications.
Radeon RX 5700 series graphics products may experience display loss when resuming from sleep or hibernate when multiple displays are connected.
Toggling HDR may cause system instability during gaming when Radeon ReLive is enabled.
Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
Performance Metrics Overlay may report incorrect VRAM utilization.
Invoking Radeon Overlay may cause games to lose focus or become minimized when HDR is enabled within Windows .
AMD has stealth-updated these drivers on Dec 12th, without an increase in version number. The new release probably adds support for the Radeon RX 5500 XT, possibly bugfixes, too.
Support For
Detroit: Become Human
Performance Improvements
An Average of 12% performance uplift in select titles with Radeon Software Adrenalin 2020 Edition 19.12.2 than with last year's Radeon Software Adrenalin 2019 edition launch driver. RS-327
Radeon Software
Introducing the new Radeon Software. A brand new, modern, accessible and powerful gaming application.
Now available via Overlay using Alt+R for fullscreen or Alt+Z for sidebar while you game!
Gaming tab lets you access games stats, view or edit media, adjust game settings and launch your favourite games directly from Radeon Software.
Streaming tab gives you a new, powerful and easy to use streaming experience with controls for streaming, viewing and editing your stream all in one area.
Performance tab lets you get detailed statistics on your current system performance or overclock and fine tune your graphics product.
User profile system that allows easy configuration for Radeon Software features, so you don't have to.
New Built-in web browser let's you lookup important game information, walkthroughs or tutorials without having to leave your game.
Radeon Boost
Provides increased performance when fast motion is detected via dynamic resolution scaling with little to no perceptible change in image quality.
Integer Display Scaling
Scale images on screen from one pixel to four or more, allowing classic games to get a retro, pixel-art-style look.
Radeon Anti-Lag
Added support for DirectX 9 on pre-Radeon RX 5000 series GPU's.
Global activation toggle to easily enable across all supported games.
Radeon Image Sharpening
Added support for DirectX 11 games.
Added controls for degree of sharpness.
Toggle on/off supported while in game.
AMD Link
Play your PC games anywhere on any mobile device without the restriction of being connected to the same home wireless network.
Cleaner interface with a unified Radeon Software look, now available across all AMD Link enabled devices.
All streaming functionality has been moved to one area for easier access.
Improved bit-rate support at up to 50Mbps.
x265 game streaming is now supported for better image quality and less bandwidth.
Instant GIF support added directly from your device.
Radeon Software Installer
'One-click' easy setup with a new and improved factory reset option.
New option to keep your settings between installations, including during factory reset.
Improved install times and error detection.
DirectML Media Filters
Visual noise reduction to apply on photos and upscaling filters available to apply on photo and media content directly from your Radeon Software media gallery.
Fixed Issues
Radeon RX 5700 series graphics products may intermittently experience loss of display or video signal during gameplay.
Out of Video Memory error may randomly appear on some Radeon R9 200/300 series graphics products when playing Fortnite with DirectX 12 API enabled.
Ring of Elysium may experience lower than expected performance on 1440p and 4K display resolutions.
Star Wars Jedi: Fallen Order may experience an application hang after the initial game cutscenes on some Radeon RX 5000 series graphics products.
Enabling Performance Metrics Overlay may cause black screens or corruption on some applications.
Task switching out of some games with Radeon ReLive enabled may cause a black screen when switching back into the game.
Known Issues
Switching between borderless and fullscreen in some games when Performance Overlay is enabled and Radeon FreeSync is enabled may cause stuttering.
Some Vulkan gaming applications may crash when performing a task switch with Radeon Image Sharpening enabled.
Applying DirectML media filters to media in Radeon Software Gallery may cause video memory to fail to be released once completed. A system restart will resolve this issue.
Integer Scaling may cause some video content to show flicker when the display resolution is set to less than native resolution.
Removing a game profile from Radeon Software may cause Radeon FreeSync and/or Virtual Super Resolution to become enabled.
Radeon ReLive may appear to be missing or not available to install on some Radeon R9 380 series and Radeon R9 285 series graphics products.
Performance Metrics Overlay may appear to lock frame rate at 60 fps when performing a task switch in or out of a game.
Battlefield V may experience an application hang when changing settings in game with Radeon Boost enabled on Radeon RX 5700 series graphics products.
Performing a resolution change while Radeon Software overlay is open may cause an application hang or TDR.
Enabling Radeon Image Sharpening on HDR enabled displays may cause colors to become washed out.
Performing Upscale on a large resolution video or screenshot may fail to apply and cause an error message.
AMD Link Known Issues
Tuning: In some cases when changing from Preset to Automatic, settings don't apply or will cycle back to the original setting.
Media: Playback of videos may reset if the device changes orientation during playback.
Media: Corruption may occur when playing back media while using the 1Mbps bitrate setting.
Gaming: Under certain conditions Now Playing changes back to Desktop or the last played game instead of displaying the currently streaming game.
Gaming: Streaming may stop if device is left idle for an extended period of time.
Fixed Issues:
Game and boost clocks may be incorrectly reported for Radeon RX 5500 XT graphics products in Radeon Software.
Radeon Software Install may experience an error and fail to detect AMD graphics hardware when a certain WiFi adapter is enabled in the system.
Rocket League may crash or experience an application hang after performing a task switch.
A black screen may occur when Performance Metrics Overlay is open and changing game resolution.
After disabling Radeon Software Overlay users may still see the toast messages for the overlay shortcut while in fullscreen games.
Audio from custom scenes may continue to play after recording or streaming has been stopped.
Installer audio has been reduced as it was too loud on some system configurations.
Some users may be unable to select drop downs in graphics settings for Tessellation Mode.
Radeon ReLive may appear to be missing or not available to install on some system configurations with Hyper-V enabled.
Newly added game profiles may fail to enable the currently selected global graphics settings options in their profile.
Performing an auto update from web to Adrenalin 2020 Edition from Adrenalin 2019 Edition may fail with an error code.
Improved Radeon Chill experience when using a gaming mouse.
MechWarrior 5: Mercenaries may experience black corruption near the bottom of the screen close to the player model.
Radeon Anti-Lag may fail to enable for DirectX 9 applications when enabled in the global graphics settings options.
Radeon Anti-Lag may fail to enable for Counter-Strike: Global Offensive .
The custom stream option may fail to present users with a url box to choose their endpoint.
DirectML Media Filters may fail to apply Upscale and Denoise when attempting to do both at the same time on one image.
Some Radeon FreeSync enabled displays may experience LFC intermittently enabling mid game causing poor performance or stutter.
A grey box may prevent users from setting custom hotkeys in the scene editor.
Performing Auto Tuning for graphics clocks on Radeon RX 5700 XT may result in an extremely high OC or unstable OC.
Some games may experience instability and screen loss or control loss when performing a task switch when the Gaming profile is set in Radeon Software which enables Radeon Enhanced Sync.
Radeon Image Sharpening may fail to enable in Star Wars Jedi: Fallen Order .
HDCP 2.2 enabled content may fail to play on some Radeon RX 500 series graphics products.
VK_KHR_timeline_semaphore (Win7 Support)
VK_KHR_shader_float_controls
This extension supports querying and overriding the default behavior of rounding modes, denormals, signed zero and infinity for floating point computations.
VK_KHR_separate_depth_stencil_layouts
The extension separates the depth and stencil bits allowing their image layouts to be set independently.
VK_EXT_tooling_info
This extension allows applications to query Vulkan tools that are active on the developer's system.
VK_EXT_pipeline_creation_feedback
This extension adds a mechanism to provide feedback to an application about pipeline creation.
Known Issues
Some Radeon R9 200, Radeon R9 300 and Radeon R9 Fury series graphics products may experience instability with a limited number of DirectX 9 or DirectX 11 games when using a high refresh rate 120hz+ display. A workaround if you are experiencing this issue is to lower your displays refresh rate.
Trials Rising may experience excessive fog/smoke in some areas of the game.
CPU usage may remain sometimes remain high once Radeon Game Advisor has been invoked during a game.
Factory Reset install may keep previously configured Radeon Software game profiles. This can cause mismatch between global graphics settings and per profile settings.
Text overflow in some UI boxes or toast messages may be experienced in some language localizations.
Controls for vertical sync may be hidden or disappear when Radeon Enhanced Sync is enabled.
Radeon Software may open with an inconsistent size or may not keep it's previously set size when opened.
Mortal Kombat 11 may experience an application crash after the splash screen on Radeon RX 5700 series graphics products.
SETI@Home may be provided incorrect results from Radeon RX 5700 series graphics products.
Support For
Monster Hunter World : Iceborne
Fixed Issues
The audible beeps at game startup from Radeon Chill, Radeon Boost, and Radeon Anti-Lag have been removed. These features now offer audible indicators only when activated or deactivated via hotkey.
The Radeon ReLive on screen timer indicator during recordings has been disabled by default but can be enabled in Radeon Software settings.
Radeon ReLive may experience freezing or pausing issues during recordings when a high resolution camera is connected and in use.
CPU usage may sometimes remain high once Radeon Game Advisor has been invoked during a game.
Some users may experience an error message "Another instance is running" during download of a software update through the Radeon Software home screen.
The DuplicateDesktop process may sometimes cause high CPU usage while a game is running.
Radeon Software may close or may experience a crash upon resuming from sleep.
The toast message detailing the hotkey to open Radeon Software's Overlay may still show up in some games after Radeon Software Overlay has been disabled.
Lost Ark may experience stuttering intermittently during gameplay.
Using a custom stream key with Radeon ReLive may fail to stream your content.
The 'Stream' button may remain active when in the process of choosing a region to stream even when a region has not been selected or chosen.
Some mjpeg clips may experience a green tint on Radeon RX 5700 series graphics products when using Windows Media Player or the Movies & TV application.
MechWarrior 5: Mercenaries may experience a game crash and DXGI dialogue error when running the game using HDMI and Radeon FreeSync display configurations.
Live streaming using the DouYu application with hardware acceleration enabled may cause video corruption on Radeon RX 5700 series graphics products.
Missing text or corruption may be experienced in the right eye when playing the VR game Boneworks .
Fixed result overflows that can be experienced with Radeon RX 5700 series when using SETI@Home.
The 'Shop AMD Products' button may open the AMD.com homepage instead of the proper shopping web link.
The scrolling arrow options may intermittently fail to work during Radeon Software installation.
Up and Down arrow keys don't work when using the search bar in Radeon Software.
Enabling HDR enabled displays in Windows may cause colors to become washed out.
Radeon Software sidebar appears behind the Windows taskbar when the taskbar is set to the same side of your display.
Playing Tom Clancy's: The Division 2 with HDR enabled and performing a task switch may cause display color corruption that persists even once the game is exited.
Mixed Reality Portal may experience color corruption or distortion near the edge of viewing areas on some headsets.
Resident Evil 2 may experience screen flashing when launching the game using DirectX 12 API.
Known Issues
The Radeon Software Overlay hotkey notification may sometimes be displayed during video playback in web browsers or launching some video player applications.
Integer Scaling option is not showing up or available on some Windows 7 system configurations.
Radeon Software may open with an inconsistent size or may not keep its previously set size when opened.
Support For
Radeon RX 5600 XT
Fixed Issues
An intermittent black screen or loss of display may occur when performing parallel actions such as web browsing, gaming or watching video.
A limited number of games such as Nioh, Dragon Quest Builders 2, WWE 2K20, Dead or Alive 6 and Atelier Ryza may crash or fail to launch.
Wolfenstein 2: The New Colossus is not detected in Radeon Software games manager.
Fan Tuning may change back to the default state when switching between available GPUs.
Copy text options are not available in the display specs table for Radeon Software.
An intermittent black screen or loss of display may occur when the system is left idle at desktop.
Known Issues
Grand Theft Auto 5 may experience a system hang or black screen at launch, when opening Radeon Overlay while in game, or after performing a task switch while in game.
Audio may intermittently be missing from Radeon ReLive recordings near the end of recorded clips.
Multiple games may have very dark or very bright graphics in game when HDR is enabled in Windows .
Radeon Anti-Lag enable and disable beep notifications may be played in error when individually pressing keys assigned to the hotkey.
Some Radeon RX 5700 series graphics users may intermittently experience a black screen while gaming or on desktop. A potential temporary workaround is disabling hardware acceleration in applications running in the background such as web browsers or Discord.
Support For
Warcraft III: Reforged
With high presets on the Radeon RX 5700 XT, achieve up to 11% better performance playing World of Warcraft III: Reforged with Radeon Software Adrenalin 2020 edition 20.1.4 than with Radeon Software Adrenalin 2020 Edition 20.1.3.RS-331
Journey to the Savage Planet
Fixed Issues
Red Dead Redemption 2 may experience square or blocky textures on some terrain during gameplay when using Vulkan API.
Some Vulkan API games may experience a crash or application hang when performing a task switch while Radeon Image Sharpening is enabled.
Text overflow is observed in toast messages for some languages.
Radeon ReLive may fail to switch recording to desktop when Radeon Software is open.
Known Issues
A loss of display with working audio may be experienced on a limited number of displays when performing a mode change on Radeon RX 5000 series graphics products.
A system crash or hang may occur when running the Final Fantasy XIV: Shadowbringers benchmark.
